Activity Forums Apple Motion variable spacing in template text objects
  • variable spacing in template text objects
    Posted by David Krummenacher on September 9, 2010 at 6:50 pm
    I am trying to create a lower third template which has two different fonts on one line of text. I can create two text “boxes” or template fields, but is there a way to adjust the spacing between them so that I don’t have an awkward gap between them?
    Patrick Harper replied 15 years, 10 months ago 3 Members · 2 Replies
  • Mark Spencer
    September 9, 2010 at 7:50 pm
    Link the position of your second text box to a dummy text field so you can control its position FCP – here’s a video that describes the process
    https://pixelcorps.cachefly.net/mbks_078_540p_h264.mov
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Patrick Harper
    November 22, 2010 at 2:58 pm
    I have followed the tutorial but when it comes to changing the Link’s Source Parameter to the Source Text’s size I do not have that option.
    The Compatible Parameters drop down menu only show Properties and Object but not Style so I cannot link it to the hidden text’s size.
    Any thoughts on where I might be going wrong?
    Many thanks,
    Patrick
    Rebuilt from scratch and works fine. Don’t think I did anything different so perhaps just a bug?
