Activity Forums Adobe Audition Variable gain
  • Variable gain
    Posted by Skye Sweeney on April 12, 2006 at 2:10 am
    I know it must be simple. I have played around with various tools, but I can’t seem to figure this out…
    I have a long track (1.5 hours) from a school play. As middle school kids, they keep their voices low when talking and let it rip when singing. The track has a huge dynamic range issue. If I just increase the amplitude accross the track it saturates for the songs. If I leave it alone the voices are too quite.
    Is there a variable gain (reduce dynamic range) function? All I need is the name of the correct tool to spend time playing with!
    I need about +18db for the real quite parts and 0db for the songs. I realize that +18 is likely to induce noise. I can live with the noise as I have some ‘silence’ that I can use for noise reduction purposes.
    -Skye Sweeney
    FLL Freak Productions
    https://www.fll-freak.com
    Willie Toth replied 20 years, 5 months ago 3 Members · 4 Replies
  • Willie Toth
    April 12, 2006 at 2:27 am
    Skye,
    The best way to do this is to just highlight the low spots one at a time with the track on the edit side and amplify it … There is too much of a gain difference to use the hard limit feature … It might take some time but it will be worth ir in the end … WILLIE
  • Ozpeter
    April 12, 2006 at 9:56 am
    Rather depends which version of Audition you are using, but another approach is to use volume envelopes in multitrack view – which can be rescaled to give more gain if need be.
    Things to look for in the manual –
    rescale
    envelopes
    If still puzzled let us know which version you are using for more targetted advice.
  • Skye Sweeney
    April 12, 2006 at 10:48 am
    I am using version 1.5 build 4124.1
    I would hate to have to manualy increase each section. It was a musical and there must be 30 songs that I would have to ease the gain change into and out of to make it smooth.
    Is there no tool that would allow me to draw a curve that says at an initial signal of -30db add 18 db gain and at 0db add 0db gain and interpolate between?
    -Skye Sweeney
  • Willie Toth
    April 12, 2006 at 2:07 pm
    Skye,
    Even if you use envelpoes you are still going to have to manually draw the line, so either method is going to take time, as to what one is faster and or easier with 1.5 I would highlight and amplify … WILLIE
