Activity › Forums › Adobe Premiere Pro › variable framerate on one timeline?
  • variable framerate on one timeline?
    Posted by Andrei Bocharnikov on January 12, 2009 at 4:35 pm
    For the first time have to use different frame rate footage (25fps and 50fps) on one timeline. Found out that if timeline settled to 25 fps then all my 50p clips looks horrible: all moving objects have half-transparent copy of it as it was done bad de-interlasing from heavily interlaced. (see attached pictures). I think it is because for every frame of timeline i have 2 frames of footage and Premier trying to blend it inbetween.
    Changing project to 50p timebase will not help because then appears problem for 25p footage…
    What is the solution to import 50p footage to 25p timeline? Or what is standard workflow of variable framerate project in PPro?
    thank you in advance for any suggestion and help
    Andrei B.
    G5 Dual 2.7 GHz, 4.5 GB DDR SDRAM, Leopard 10.5.6, QT 7.5.5
    FCS2
    Andrei Bocharnikov replied 17 years, 8 months ago 1 Member · 2 Replies
  • Andrei Bocharnikov
    January 12, 2009 at 4:42 pm
    sorry, pictures attachement system is very strange here… they just did not appear together with the message. uploading one more time:
    January 12, 2009 at 8:16 pm
    just found two workarounds:
    1. put clip to timeline, right-click –> frame blending off (default is on)
    2. in the bin I right-click on the clip and select “interpret…”, then drop the clip to timeline and i have slomo video, then i just speed it up double or timewarp it.
    Any idea how to make frame blending option OFF by default? Then I would avoid whole headache of turning it off for each and every 50p clip?
    FCS2
