Activity › Forums › Adobe Photoshop › Variable for Layer name and use in Actions
  • Variable for Layer name and use in Actions
    Posted by Gab Arito on February 2, 2018 at 7:11 pm
    Hi everyone.
    I’m doing a sequence of numbers to show a countdown counter, in the shape of those digital clock plates.
    Like this:
    Since there are 10 numbers and several frames of each number to do the animation, I thought about creating a sequence of actions.
    I created the actions for one number and would like to apply it to the remaining nine ones.
    But I came across a serious impediment: the actions use the name verbatim of each layer and do not lend themselves to be applied in the other layers.
    For example, I created layer 9 that will transition to layer 8.
    I made transformations in layer 9, made selections and made copies of layer 8.
    If I apply this to layer 1, of course it will not work, because the action will look for layers 9 and 8.
    Searching, I found references to using variables in the Image menu.
    But from what I could understand, those variables will not be useful to me.
    I was looking for something that would do the actions in layers that were referenced by variables and not by the name of each layer.
    In a manner that I only had changed the variable by its-turn layers, applying the actions generically on layers 1 and 2, then 2 and 3, and so on.
    Attached are a template file and my palete of Actions for colleagues to take a look at what I’m doing.
    Thank you for any suggestion and/or change of procedure.
    Because I’m not a Photoshop expert, I may be going down a more complicated path than I would have thought.
    Incidentally, I even ask for an opinion about the transformations that I made trying to simulate a 3-D board turn.
    As I said before not being an expert, it is only today that I “discovered” the 3D features of the program.
    Who knows what animation I’m trying to do would be better represented by using this feature?
    Waiting suggestions.
    Thank you.
    12119_plates.zip
    12117_actionspalette.psp.zip
    Guidance on how to use Actions:
    Open the Plaques.psd file
    Perform Action “Number Only”
    Execute Action “Style 1 – Bold”
    Perform Action “Center”
    Perform Action “Detach in the middle”
    Perform Action “Make Plates”
    Perform Action “Transformation”
    Gab Arito replied 8 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
