Activity Forums Apple Final Cut Pro Legacy Variable bitrate and different fps settings
  • Variable bitrate and different fps settings
    Posted by Joshua Boswell on April 29, 2015 at 10:47 am
    I have a very bizarre question.
    I have two iMacs, both running the exact same version of FCP X and Compressor 4 (I did a clean install to make sure… including cleaning out preference files, etc…), using the exact same settings.
    When I export video on the one iMac (Mid-2010, 2.93, i7), it gives me beautiful files and all the settings are right.
    When I export video on the other, it changes two critical things… specifically the bitrate and the fps settings.
    Using, MediaInfo, I pulled the Metadata for both exports. Notice that in the “good export’ the fps only has one setting: 29.97
    Then notice that the bad file has two fps settings… 29.97 and 25.0
    Also notice that under General, with the good export, it shows “overall bitrate”, but with the bad file, it shows “bitrate mode: variable”
    I have checked and double checked all my settings. To me all settings in FCP and Compressor on both of these computers are EXACTLY the same.
    I’m wondering if the graphics cards is changing this? Or could it be a setting somewhere else?
    It is really bizarre to me.
    Any ideas?
    ***********Good Export**********
    General
    Complete name : /Volumes/My Book/Test Run/JBP-Week-Zero-Welcome-1.a.ii-TEST.mp4
    Format : MPEG-4
    Format profile : Base Media / Version 2
    Codec ID : mp42
    File size : 92.6 MiB
    Duration : 8mn 16s
    Overall bit rate : 1 563 Kbps
    Movie name : JBP-Week-Zero-Welcome-1.a.ii
    Encoded date : UTC 2015-04-29 01:18:00
    Tagged date : UTC 2015-04-29 01:28:29
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L3
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Format settings, GOP : M=2, N=30
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 8mn 16s
    Bit rate : 1 493 Kbps
    Width : 640 pixels
    Height : 360 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.216
    Stream size : 88.5 MiB (96%)
    Title : Core Media Video
    Color range : Limited
    Color primaries : BT.601 NTSC
    Transfer characteristics : BT.709
    Matrix coefficients : BT.601
    Audio
    Format : AAC
    Format/Info : Advanced Audio Codec
    Format profile : LC
    Codec ID : 40
    Duration : 8mn 16s
    Source duration : 8mn 16s
    Bit rate mode : Constant
    Bit rate : 64.0 Kbps
    Channel(s) : 2 channels
    Channel(s)_Original : 1 channel
    Channel positions : Front: C
    Sampling rate : 44.1 KHz
    Compression mode : Lossy
    Stream size : 3.86 MiB (4%)
    Source stream size : 3.86 MiB (4%)
    Title : Core Media Audio
    Language : English
    *******************Bad Export**********
    General
    Complete name : /Users/jtboswell/Downloads/JBP-Week-Zero-Welcome-1.a.ii-TEST.mp4
    Format : MPEG-4
    Codec ID : mp42
    File size : 76.6 MiB
    Duration : 8mn 14s
    Overall bit rate mode : Variable
    Overall bit rate : 1 300 Kbps
    Encoded date : UTC 2015-04-28 22:08:37
    Tagged date : UTC 2015-04-28 22:09:55
    Video
    Format : AVC
    Format profile : Main@L3.1
    Codec ID : avc1
    Duration : 8mn 14s
    Bit rate mode : Variable
    Bit rate : 1 197 Kbps
    Maximum bit rate : 768 Kbps
    Width : 854 pixels
    Height : 480 pixels
    Original frame rate : 25.000 fps
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.097
    Stream size : 70.5 MiB (92%)
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 8mn 14s
    Source duration : 8mn 14s
    Bit rate : 96.0 Kbps
    Stream size : 5.77 MiB (8%)
    Source stream size : 5.77 MiB (8%)
    Language : English
    Joshua Boswell replied 11 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
