Activity › Forums › Compression Techniques › Variable bit rate (VBR) output with constant bit rate (CBR) settings?
  • Variable bit rate (VBR) output with constant bit rate (CBR) settings?
    Posted by Shirin Ho on November 28, 2012 at 6:54 am
    I am trying to transcode a SD clip via compressor. Here’s the settings that I would like to achieve.
    Video Frame Rate
    25 fps
    Video Standard
    PAL
    Video Codec
    MPEG-2 Video, Main Profile/Main Level
    Audio Codec
    MPEG-2 Audio Layer II or
    Available audio codec
    Container Format
    Mpeg-2 Transport Stream (mpg)
    Video bit rate
    8,000 Kbps, CBR
    Audio Bit rate
    384 Kbps
    Aspect Ratio
    16:9
    Audio Sample Rate
    48KHz
    Resolution
    1024×576
    Scan type
    Progressive
    However, the only problem I have is transcoding the clip to CBR mode. Even though I have chosen the ‘one-pass CBR mode’ in Compressor, the output is still VBR mode. Is there any way for Compressor to follow the settings and achieve the CBR mode? Thanks in advance.
    Mac OS X (10.6.8)
    Shirin Ho replied 13 years, 10 months ago 1 Member · 0 Replies
  • 0 Replies
