Activity Forums VEGAS Pro Variable audio time-stretching in Vegas?
  • Variable audio time-stretching in Vegas?
    Posted by Marker7 on November 19, 2006 at 11:30 pm
    Hello,
    One problem I have in Vegas 7 is that when I vary the velocity of a video clip via a velocity envelope there is no way to make the audio match this, aside from manually time-stretching a lot of little bits of the audio clip to get an approximate match.
    Is there any way to automatically time-stretch the audio to sync with the video, or to create an audio velocity envelope? If not, what is the simplest method that you have found for doing this sort of variable audio time-stretch?
    Mark
    Gary Kleiner replied 19 years, 10 months ago 2 Members · 1 Reply
  • Gary Kleiner
    November 20, 2006 at 5:07 am
    You can strectch audio the same way as video by Ctrl/Dragging the event. To do multiple events, group them with the G key, and when you stretch one, they all will stretch.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
