Activity Forums Adobe After Effects Expressions Variable 2nd position keyframe. (first one is locked)
  • Variable 2nd position keyframe. (first one is locked)
    Posted by Rob Nairn on September 24, 2020 at 6:15 am
    Hi everyone,
    I’m creating some mogrts. I’d like one of the available variables to control the x position of the 2nd key frame of an object.
    In other words I want it to always start at the same place, but be able control where it goes to horizontally, via a slider control.
    I’ve done some searching and nothing I’ve found seems to fit the bill.
    Thanks in advance.
    Rob Nairn replied 5 years, 11 months ago 3 Members · 5 Replies
  • Chris Voelz
    September 24, 2020 at 2:58 pm
    Try setting the second keyframe to the max position for your comp and then use the slider to offset the value?
  • Rob Nairn
    September 24, 2020 at 11:43 pm
    Hi Chris,
    I’m getting stuck writing an expression where the slider only controls that second keyframe rather than both.
  • Stephen Dixon
    September 25, 2020 at 12:53 am
    Using an interpolation function like linear() will allow you to transition from one value to another over time. E.G.:
    let kf1 = transform.position.key(1);
    let kf2 = transform.position.key(2);
    linear(kf1.time, kf2.time, kf1.value, [sliderVal, kf2.value[1]])
    You could also use ease(), easeIn() or easeOut() in place of linear, for smoothly eased motion.
  • Chris Voelz
    September 25, 2020 at 4:01 pm
    It took me minute to wrap my head around this, i’ve never used the key() before. After testing I was able to get this to work well for me.
    p = thisLayer.transform.position[0];
    k1 = key(1).value[0];
    k2 = key(2).value[0];
    v = k2 + effect("Slider Control")("Slider");
    [linear(p,k1,k2,k1,v),540]
  • Rob Nairn
    September 27, 2020 at 11:22 pm
    Thanks Chris and Stephen. I’ll give these a go, thanks for your help so far.
