Activity Forums Adobe After Effects Vanishing Point problem
  • Vanishing Point problem
    Posted by Regina Alonte on October 13, 2007 at 5:31 am
    I am new to AE CS3 and have been trying the https://www.adobe.com/designcenter/video_workshop/ “Vanishing point to map 3-D” tutorial, but when I import the .vpe data and look at the comp that AE created it is always rotated 90 to 180 degrees and is way off to the side, and pointed away! I followed the tutorial to the letter several times now and get the same results.
    That doesn’t happen in the tutorial! What is going on? Is there a special setting that I didn’t set when I installed AE CS3? Does it have to do with how the grid is made in PS CS3? Help appreciated.
    Brad Bartkus replied 18 years, 9 months ago 3 Members · 2 Replies
  • David Franklin
    October 21, 2007 at 5:35 pm
    I’m having the same problem. I’m also having problems inside Photoshop, where when I try to make perpendicular planes, they’re coming off at crazy angles. This, too, did not happen in the tutorial. Anyone out there more knowledgeable and want to share?
    Thank you!
  • Brad Bartkus
    November 19, 2007 at 8:52 pm
    I’m getting the same crap. I had to really mess with all of the position and rotation settings to get it to look like the Photoshop file.
