Activity Forums Adobe After Effects vanishing point like depth thoughts?i
  • vanishing point like depth thoughts?i
    Posted by Adam Lewen on November 30, 2017 at 10:00 pm
    Hi
    What other methods can be used for achiving depth from a 2d image.
    i know its a bit of a general question.
    I am thinking of the direction of vanishing point in Photoshop to AE and\or Parallax bg and fg…
    Any thought is appreciated
    Kalleheikki Kannisto replied 8 years, 9 months ago 2 Members · 2 Replies
  • Adam Lewen
    December 1, 2017 at 1:35 pm
    Hi Dave.
    As I wrote in the subject, Vanishing point.
    A fairly old-school photoshop to ae trick to give a 3d like effect to a suitable (plane-able) image.
    example
    https://youtu.be/1h58yBFXE-A
    And the well known parallex background and forground is another method im playing with…
    im looking for some more, even general, ideas of turning simple 2d images to a more interesting and/or visually appealing…
    thanks
  • Kalleheikki Kannisto
    December 4, 2017 at 11:18 am
    A manually created z-depth channel can be pretty useful. It looks better if used with a plugin that can create a 3D object out of the map (Freeform Pro or Mir, for instance), but can also be used, to a limited degree, with the displace effect. A combination of a manually created depth channel with a grayscale version of the original image itself overlaid onto it at low opacity (a sort of a bump map) gives much more detail into the depth map.
    Senior Graphic Designer
