Activity Forums Adobe After Effects Expressions valueAtTime property gives “undefined” error
  • valueAtTime property gives “undefined” error
    Posted by William Meese on December 8, 2009 at 12:28 am
    The goal is to vary an effect’s property using the layer’s horizontal velocity, caused by animating its anchor point.
    My thinking is that the expression
    transform.anchorPoint[0]-transform.anchorPoint[0].valueAtTime(time-(1/24))
    Should give the horizontal velocity for the frame.
    But while just
    or just
    don’t return errors,
    returns the error
    “Function transform.anchorPoint[0].valueAtTime is undefined”
    What am I doing wrong?
    William Meese replied 16 years, 9 months ago 3 Members · 4 Replies
  • Xinlai Ni
    December 8, 2009 at 12:30 am
    try valueAtTime(…)[0] instead.
    BTW, anchorPoint.speed is more general (you don’t have to write the frame rate).
    Xinlai Ni
    Software Engineer, Google Inc.
  • William Meese
    December 8, 2009 at 3:15 am
    I thought “speed” would give the actual distance moved, whatever the direction, while I need just the horizontal component.
    Your “try valueAtTime(…)[0] instead” tip confused me for a while, but it clicked: valueAtTime is a property, so it needs to come before specifying the dimension.
    “transform.anchorPoint[0]-transform.anchorPoint.valueAtTime(time(1-24))[0]”
    is working. Thanks!
  • Dan Ebberts
    December 8, 2009 at 3:47 am
    How about just this?
    transform.anchorPoint.velocity[0]
    Dan
  • William Meese
    December 8, 2009 at 7:18 am
    When I RTFM I find that “speed” always returns a 1D, positive value, but”velocity” returns a result w/ the same dimension as the property.
    So thanks, Dan; a more elegant solution.
    When I plug it in, the results are similar but not identical–perhaps a matter of which chunk of the timeline is being sampled; my original math samples the frame before, “velocity” is probably the value at the instant of the frame start.
    At least now the expression functions. Onward–and thanks again, guys.
