Activity Forums Maxon Cinema 4D valueAtTime in Xpresso
  • valueAtTime in Xpresso
    Posted by John Mcmullin on June 26, 2017 at 11:17 am
    I use expressions with After Effects and so I’m trying (perhaps wrongly) to do the things the same way in C4D.
    I can’t work out how to set up Xpresso to return a value for an object’s position at an earlier or later time. I want to create a chain of objects following each others’ positions.
    I tried to do it with a cloner and splines but this gives me trouble when I want to affect other properties of the separate objects, like opacity or scale.
    Thanks a lot for any help.
    John
    John Mcmullin replied 9 years, 1 month ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 26, 2017 at 7:21 pm
    What you’re looking for is the Xpresso Memory Node.
  • John Mcmullin
    June 26, 2017 at 11:20 pm
    Thanks so much Adam,
    That pointed me in the right direction. This tutorial and the one following explain it all really well:
    https://www.youtube.com/watch?v=zVtK3z4mYp8
    Best wishes,
    John
