Activity Forums Adobe After Effects Expressions valueAtTime in both directions
  • valueAtTime in both directions
    Posted by Julian Chojnacki on December 3, 2022 at 3:16 am
    Hi folks,
    let’s say I have a keyframed animation that goes from 0 to -500 in Z space and back to 0 again and a layer that references that with valueAtTime and a -.1 delay.
    I want the delay to adapt to the change of direction, which works with this code:
    src=thisComp.layer(index-1)
    v=src.transform.position.velocity;
    let delay;
    if(v[2] >= 0) {delay = -.1} else {delay = .1};
    src.transform.position.valueAtTime(time-delay);
    Unfortunately, this generates two problems:
    1. On the first frame of the animation, which starts in the beginning of the comp, the position value jumps to -107.8, while it should be 0 since the animation it references is at 0 as well.
    2. One frame before the -500 keyframe and the direction switch, the delayed layers jump values, which makes it look choppy like a few frames have been skipped, due to the nature of the adaptive delay, which switches values abruptly.
    This code fixes the first problem:
    const src=thisComp.layer(index-1);
    const v = src.transform.position.velocity;
    let delay;
    if (time == 0){
    [value[0],value[1],value[2]];
    }else{
    (v[2] >= 0) ? delay = -.1 : delay = .1;
    …but the other persists.
    Any help would be fantastic 🙂
    Julian Chojnacki replied 3 years, 9 months ago 2 Members · 3 Replies
  • Julian Chojnacki
    December 3, 2022 at 4:01 am
    Update: cranking up the easing to 100 on the -500 keyframe fixed the problem…
  • Max Haller
    December 4, 2022 at 4:04 am
    see if this helps too
    const src = thisComp.layer(index-1);
    let delay;
    if (time == 0) {
    // Set the position to the initial value at time 0
    [value[0], value[1], value[2]];
    } else {
    // Check if the velocity is greater than or equal to 0
    if (v[2] >= 0) {
    // If the velocity is positive, check if the previous delay value was negative
    if (delay < 0) {
    // If the previous delay was negative, interpolate between the previous value and -0.1 to smooth out the transition
    delay = linear(time, time-thisComp.frameDuration, time, delay, -0.1);
    } else {
    // If the previous delay was not negative, set the delay to -0.1
    delay = -0.1;
    } else {
    // If the velocity is negative, check if the previous delay value was positive
    if (delay > 0) {
    // If the previous delay was positive, interpolate between the previous value and 0.1 to smooth out the transition
    delay = linear(time, time-thisComp.frameDuration, time, delay, 0.1);
    } else {
    // If the previous delay was not positive, set the delay to 0.1
    delay = 0.1;
    // Use the calculated delay value to get the position value at the current time
    src.transform.position.valueAtTime(time - delay);
  • Julian Chojnacki
    December 5, 2022 at 7:59 pm
    Max, you nailed it! Thanks for the proper education 😉
