Activity Forums Adobe After Effects Expressions valueAtTime from a keyframe is nothing????
  • valueAtTime from a keyframe is nothing????
    Posted by Eden Exposito on April 8, 2009 at 6:38 pm
    Hi again!
    Im using this expression for controlling a values from keyframe position in time with layer keymarkers
    x1=marker.key(“1”).time
    x2=marker.key(“2”).time
    x3=valueAtTime(key(1).time)
    x4=valueAtTime(key(2).time)
    linear(time,x1,x2,x3,x4)
    All works correctly, but…
    I want print this “valueAtTime(key(1).time)” with a layer text
    I had tested adding this on source in a text layer:
    valueAtTime(thisComp.layer(“solid 1”).scale.key(1).time)
    no expression errors but i dont see anything, :S i want see these x1,x2,x3,x4 values for understand really all.
    Eden Exposito replied 17 years, 5 months ago 2 Members · 2 Replies
  • Dan Ebberts
    April 8, 2009 at 7:55 pm
    This should work:
    L = thisComp.layer(“solid 1”);
    L.scale.valueAtTime(L.scale.key(1).time)
    Dan
  • Eden Exposito
    April 9, 2009 at 8:21 am
    thanks! dan you are a master
