Activity Forums Adobe After Effects Value by position movement
  • Value by position movement
    Posted by Yanda Satria on March 29, 2019 at 8:06 pm
    Hi, sorry but i need help with expressions…
    so, i have this layer, and i want it to glow when it moves up on Y axis, and the glow will turn off when it goes down…
    i was thinking something like,
    if(pos Y value decreasing, glow value will goes immediately to 100) if(pos Y is increasing, glow value will immediately goes to 0)
    or maybe like on off expression like if(100, else=0)
    but i don’t know what’s the correct expression format for that…
    there’s a lot of that movement, this is actually for equalizer bars, so you can imagine what a real pain it is to do manual keyframe..
    FYI i am using separate XYZ position if that matters,
    thank you very much… ☺
    ps. sorry for my bad english
    \”We will either find a way, or make one\”.
    -Hannibal Barca-
    Yanda Satria replied 7 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
