Activity Forums DaVinci Resolve V8 – Prores Playback Issue
  • V8 – Prores Playback Issue
    Posted by Jose Lomeña on June 30, 2011 at 10:39 am
    Hi. I have a very slow performance with playback of prores at 4k 4096×2304 with project settings 1920×1080.
    My performance with resolve 7.1 is 42fps playback without nodes
    My performance with resolve 8 is 13fps playback without nodes
    What can I do for better performance with v8?.
    I have both version in the computer but, with resolve 7 appears this message
    Decoder client version 3.2.1 does not match Digital powerhouse version 4.2.0
    I can work with prores files without problems, but not r3d. Is there any form to have both versions at the same time?
    Thanks.
    Jose Lomeña
    Peter Chamberlain replied 15 years, 2 months ago 5 Members · 8 Replies
  • 8 Replies
  • Adam Hendershot
    June 30, 2011 at 11:17 am
    Before installing v8, I dragged the Resolve package for v7 out of the Applications folder. v7 seems to run fine from its new location and v8 from the Applications folder where it installed itself.
  • Adam Hendershot
    June 30, 2011 at 11:23 am
    I should probably mention also that I did not update my 7.1 database, I created a new one in v8.
  • Jose Lomeña
    June 30, 2011 at 11:26 am
    Con you playback r3d files correctly?
  • Rohit Gupta
    June 30, 2011 at 12:32 pm
    Could you please send your logs to davincihelp@blackmagic-design.com?
    You can’t switch between v7 and v8 like that. You need to reinstall using the installer to switch.
  • Jose Lomeña
    June 30, 2011 at 12:40 pm
    Ok, no problem what that. What I need is to improve prores performance at 4k.
    Do you know why so much diference between v7 and v8?. Can you replicate the same problem?, i’m testing with prores 422 hq, because 444 has a lot of crash at 4k.
  • Joseph Mastantuono
    June 30, 2011 at 4:44 pm
    Do you have a quick workflow on how you did that Adam? I’d like to have both concurrent.
    Joseph Mastantuono
    Online Editor – Colorist – Post Consultant
    Brooklyn based finishing at reasonable prices
    917.969.1583
  • Adam Hendershot
    June 30, 2011 at 4:56 pm
    I’m out of the office so I can’t check the r3d playback. What I did test was .ari raw and ProRes in ver 7.1 and it seemed to function normally after installing 8.
    I simply dragged the application package for Resolve 7.1 onto the desktop, then installed version 8. When I ran version 8 and it complained about the database, I created a new one rather than update the old one. Version 7.1 runs from the desktop where I put it.
    There may be things that aren’t working, since it’s not supposed to be done and I haven’t had a lot of time to play with it, so keep that in mind.
  • Peter Chamberlain
    July 1, 2011 at 12:56 am
    Logs.
    You can find them at
    Macintosh HD/Library/Application Support/Blackmagic Design/DaVinci Resolve
    There is also a capture logs app in the same folder.
    Please send them to
    Peter
