Activity Forums VEGAS Pro V6 AC-3 Dynamic Range Compression Question
  • V6 AC-3 Dynamic Range Compression Question
    Posted by Michael Morone on July 14, 2005 at 3:45 pm
    I needed to render audio (and video but my question concerns the audio) in Vegas 6 to AC-3 because I wanted to later put it on a DVD. The original avi audio was really bad to begin with so in Vegas 6, wanting to equalize the sound, I used the volume envelope tool. When I finally rendered it, the AC-3 file’s volume was much lower than I expected and was originally. I then searched the forum for problems similar to mine and I discovered that the Default settings for rendering AC-3 stereo changes the original audio. I also found a way to fix this on this forum and this is where my question comes in.
    I have read that for unaltered audio the “Dialog normalization” option should be set to -31dB -27dB and the “Dynamic Range Compression Line mode profile” option should be set to “None” instead of “Film: Standard”. What about the “Dynamic Range Compression RF Mode Profile” option? Should that be set to “None” too? Is this all I have to change to make the audio unaltered?
    Thanks for any help,
    Michael M.
    Dennis Vogel replied 20 years, 10 months ago 5 Members · 8 Replies
  • 8 Replies
  • Edward Troxel
    July 14, 2005 at 4:13 pm
    When rendering to AC3 format, the volume will be automatically reduced. If you wish to prevent this from happening, make the following setting changes:
    Change the dialog normalization to -31
    On the PreProcessing tab, change both the Line mode profile and RF mode profile to NONE.
    Edward Troxel
    JETDV Scripts
  • Jerry Jesion
    July 14, 2005 at 4:29 pm
    Edward,
    Do you know if DVDA3 drops the volume when rendering from AVI? If so, how would one avoid this, and do you know why this is done?
    Regards,
    Jerry
  • Edward Troxel
    July 14, 2005 at 4:32 pm
    I believe you will have to render from Vegas to prevent this from happening.
    Edward Troxel
    JETDV Scripts
  • Michael Morone
    July 14, 2005 at 4:40 pm
    Thank you very much for the quick response and the clarification.
    I have one more quick question:
    [jeditdv] “When rendering to AC3 format, the volume will be automatically reduced.”
    Is the reduction of the volume constant throughout the entire track? When it reduces the volume, does it reduce the volume in such a way that the result is similar to moving the track volume next to the time line down or is it more complex than this? I hope my wording isn’t too confusing.
    I am asking this becuase I am wondering whether I can just render the avi audio to AC3 without equalizing the volume manually. I’m not sure which would give a better result but I can compare later.
    Thanks again for the help,
    Michael M.
  • Edward Troxel
    July 14, 2005 at 5:09 pm
  • Michael Morone
    July 14, 2005 at 5:58 pm
    Thanks, that cleared things up for me.
  • Peter Wright
    July 15, 2005 at 2:28 am
    Don’t forget also that you only have to use ac3 if you’re “pushed for space” on the DVD.
    You can set the audio in DVDA to be PCM wav and avoid these compression issues.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Dennis Vogel
    October 27, 2005 at 9:21 pm
    I would suggest you use AC3 all the time. AC3 is very good and it’s very difficult to detect the difference between it and PCM. In addition, PCM takes up about 8 TIMES the space of a typical stereo AC3 track. For 2 hours of video (a typical amount to try to fit on a standard DVD) PCM would need almost 1.4 GB of the 4.7 GB total. AC3 would take up 176MB. I’d rather have those extra 1.2 GB allocated to the video.
    As always, YMMV.
    Good luck.
    Dennis
