Activity Forums Avid Media Composer V3 not visible
  • V3 not visible
    Posted by Frederic Lumiere on October 5, 2012 at 12:39 am
    Hmm, I know I must be missing something but I have 3 video tracks. V1, V2, V3
    If I monitor V2 (which is above V1): V1 & V2 are visible.
    If I monitor V3 (which is above all of them) V1 & V3 are visible but not V2!?
    What am I missing?
    Glenn Sakatch replied 13 years, 11 months ago 3 Members · 4 Replies
  • Shane Ross
    October 5, 2012 at 2:48 am
    V3 is covering what is on V2. Do you have something like Picture in Picture or an Animatte set up so you can see through V3?
    Shane
    Little Frog Post
  • Glenn Sakatch
    October 5, 2012 at 6:53 pm
    First thought…is it called V3 because you reordered V2 and V3 and then renamed it to V3 because it is now on the top? (or is actually the 3rd track that was created?)
    Second thought- a screen grab of the situation might help.
    Glenn
  • Frederic Lumiere
    October 6, 2012 at 4:35 am
    I think I might’ve renamed video tracks and reordered them… can’t remember now. Somehow, when I add a video track, it doesn’t add it on top. Here’s a screen shot.
    Basically I get no image from V3 but if I play the playhead, V2 &V4 will show an image. Thx!:
  • Glenn Sakatch
    October 6, 2012 at 4:14 pm
    That is probably your problem. When you move tracks around on Avid, they retain their original layer
    hierarchy. Weird but true.
    If you create 6 tracks and then delete number 4…then create a new track, it will simply recreate a V4 for you .
    Glenn
