Activity › Forums › Maxon Cinema 4D › UVW’s and sweep nurbs
  • UVW’s and sweep nurbs
    Posted by Michael Goldberg on October 6, 2009 at 3:08 pm
    I came across an interesting dilema. I have created a vine using a sweep nurbs. I wasn’t happy with the default UVW texture ofcourse, and none of the base projection methods looked great. I decided to turn to bodypaint, and paint the texture onto the vine. This gave me the control to create a pretty decent texture (try tweaking the UVWS on a twisting sweep nurbs, this I gave up on). In order to paint in bodypaint, I needed to convert my sweep nurbs to a polygon surface. I thought Once I created the texture, I could copy the UVW map from the polygonal vine to the sweep nurbs, and the projection would be the same. This didn’t work. I want to use the sweep so I can animate the end position so it grows. I’ve posted the file here:
    https://clientshare.ccfv.com/
    user: gold
    pass: goldtemp
    file: vine
    Thanks for any suggestion,
    Mike
    Michael Goldberg replied 16 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
