Activity › Forums › Maxon Cinema 4D › UVW with Procedural Textures
  • UVW with Procedural Textures
    Posted by Andy Henik on September 2, 2008 at 9:24 am
    Hi there,
    I created an organic object and attached to it a procedural Texture including Fresnel as a color material, and Noice as a Bump and displacement material.
    My problem is when I add to it a modifier such as wind, bend taper and so on. The UVW coordinates don’t work with it. I also used the Stick Texture Tag, and it doesn’t work. any suggestions?
    Adam Trachtenberg replied 18 years ago 3 Members · 9 Replies
  • 9 Replies
  • Randy Johnson
    September 2, 2008 at 10:43 am
    have you tried different projection settings like cubic?
    /randy
  • Andy Henik
    September 2, 2008 at 10:56 am
    No I have not. I thought that if you want to stick a texture on an Object, you need to use UVW coordinates. Why would cubic mapping help me though?
  • Randy Johnson
    September 2, 2008 at 11:11 am
    you can use any projection type you want if it looks right.
    I am played with some textures here and had no issues with the texture so long a stick texture was applyied. Can you post a file?
    /randy
  • Andy Henik
    September 2, 2008 at 11:24 am
    How can I post a file? I have created one, but I don’t know how to upload it.
  • Randy Johnson
    September 2, 2008 at 11:28 am
    You cant post here… you could use an ftp or you can post the question at c4dcafe.com and post it there.
    Or you can use
    https://skickafilen.se/
    Mottagarens e-postadress:
    randyarchy@yahoo.com
    Meddelande:
    (your own message)
  • Andy Henik
    September 2, 2008 at 11:36 am
    I posted it at https://skickafilen.se/ to your mail address
  • Randy Johnson
    September 2, 2008 at 12:38 pm
    i still have not recieved the file… let you know when i do.
    /randy
  • Randy Johnson
    September 2, 2008 at 1:39 pm
    I applied a stick texture and it stayed in place.
    You can check this sort of thing with by making a checkerboard texture (premade in the the surface drop down)
    Then watch with the wireframe visible.
    /randy
  • Adam Trachtenberg
    September 3, 2008 at 3:19 pm
    First, the stick texture tag is only necessary if you are using a projection type *other* than UVW mapping. Second, no matter what type of mapping you use, your noise won’t follow the deformed object unless its “Space” is set to either UV (2D) or Texture.
