Activity › Forums › Apple Final Cut Pro Legacy › UVW-1800 shuts off on edit to tape
Posted by Chris Borjis on March 25, 2008 at 11:06 pmBeen having this odd issue once every couple of weeks
with a Sony BetaSP UVW-1800.I put the tape in, go to edit to tape and when
the motor engages the unit shuts off.I have to then unplug the power chord and let
it sit for a few minutes before it will come
back on again.Anyone had this issue?
Cory Caplan replied 18 years, 6 months ago 5 Members · 13 Replies -
Walter Biscardi
March 25, 2008 at 11:32 pmThat’s a Sony issue. Take that machine in to a repair shop as soon as you can.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Read my Blog!
Chris Borjis
March 25, 2008 at 11:35 pmhave you had that happen on an 1800 walter?
just curious to know if its a common problem.
but yeah its going in for service anyway.
Walter Biscardi
March 25, 2008 at 11:43 pm[Chris Borjis] “have you had that happen on an 1800 walter?”
Nope. My 1800 is almost 8 years old now and all we do is take it in every so often for head cleanings. It’s a very reliable workhorse for us.
That’s why I think it’s a Sony issue. Probably a bad sensor in there or something.
Read my Blog!
Chris Borjis
March 26, 2008 at 12:35 amyeah we’ve had this one for just over 9 along with
another one that has 3x as many hours.Great little decks 🙂
Colin Mcquillan
March 26, 2008 at 5:20 amWe have one here that does the exact same thing. The power supply went flakey. Like yours, happens when tape transport locks in. Power just cuts out.
Colin McQuillan
Vancouver BCOcto 3.2, 8gig, 8800GT, 2×23″ ACD, 2TB G-Speed eS, Kona LHe….
MBP 2.4, 4gig , 2xLacie Quadra 500gig…. -
Cory Caplan
March 26, 2008 at 7:05 amI’ve had this problem with 3 different UVW-1800’s and it always manifests in the same way.. My question to you is, did you turn the deck on after FCP had initialized? I noticed a while back that these UVW-1800s all turned off, then could not be turned on for a few minutes ONLY when deck control was activated after a late turn-on.
I had this problem with AVID and FCP on different systems.. I assumed it was some sort of overload protection for the serial port.. My current deck is an 1800 and has done this since I’ve had it.. Last 1800 and a colleague’s reliably do the same thing.. (when turned on after “capture tool” is open in Avid, or after FCP/Aja initializes)
So the million dollar question is– when did you turn your deck on?
Cory
Bob Flood
March 26, 2008 at 2:26 pmHi
Its a good idea to turn on your deck before you even start your computer If not, at least before you open log and capture. FCP wants to see a deck out there (on the RS422 line) when it opens the log and capture window. Because you are doing it after you open L and C, it may be corrupting the drivers
hope this helps
“I like video because its so fast!”
Bob Flood
Greer & Associates, Inc. -
Cory Caplan
March 26, 2008 at 2:31 pmYeah, I thought that was implicit in my answer, but I guess I shoulda said that more clearly…
Chris Borjis
March 26, 2008 at 3:52 pm[Cory Caplan] “when did you turn your deck on?”
Just before making the dubs around 11am.
the fcp system had been on since 9am.
another lovely but rare issue with my DVW-500 digibeta is that
sometimes, after an insert/assemble to tape, the
mac has a kernel panic…..but thats a software
issue with the multibridge extreme. -
Chris Borjis
March 26, 2008 at 3:54 pm[Bob Flood] “Its a good idea to turn on your deck before you even start your computer If not, at least before you open log and capture. F”
oh I definitely turn it on before I open log and capture,
but the deck stays off all day unless I’m going to use
it. No sense wasting electricity and my other 1800
does not have this problem.I suspect its the power supply like someone else mentioned.
