Activity Forums Maxon Cinema 4D UV mapping question
  • UV mapping question
    Posted by Chad Demoss on August 13, 2018 at 7:45 pm
    I’m not sure what the issue is but I’m trying to UV map a simple cylinder surface. the only projection that isn’t stretching the texture is box and flat. box works but I want one continuous piece not 4 pieces. I haven’t tried uv mapping anything besides cube shaped things so far so I’m probably missing some step.
    Chad Demoss replied 8 years ago 1 Member · 0 Replies
  • 0 Replies
