Activity › Forums › Maxon Cinema 4D › UV mapping problem (newbie)
  • UV mapping problem (newbie)
    Posted by Vera Nazarenko on November 26, 2017 at 2:34 pm
    Hello,
    I just did the texturing in C4D for the first time, and I followed every recommendation of the tutorial where very similar mapping was done. However, I ended up with some strange glitch:
    When I pan or zoom on the object, it is changing in the viewport and in the render view.
    What is going on? Thank you very much in advance!
    Vera Nazarenko replied 8 years, 10 months ago 2 Members · 2 Replies
  • Brian Jones
    November 26, 2017 at 6:40 pm
    it’s hard to tell without the scene file but that look like what you get if you have two surfaces in exactly the same place
  • Vera Nazarenko
    November 26, 2017 at 8:59 pm
    Yes, it turned out that I have not switched the copies off! Thank you very much Brian!
