Activity Forums Maxon Cinema 4D UV distortion
  • Adam Trachtenberg
    April 21, 2013 at 1:09 pm
    Some of your UV polygons are much larger than others, relative to the geometry they are covering. You might try the “Relax UV” function in BP to even things out.
  • Manojit Ghose
    April 21, 2013 at 1:31 pm
    Hi Adam,
    Thanks for the response, I did try the UV relax function. With both algorithm options, It didn’t help me a lot. I found this function is not controlable unlike for example in 3dmax. (unless I. Am missing the control function in BP). Do you know any step by step article, That explains resolution of such an issue?
    MG
