Activity › Forums › Apple Final Cut Pro Legacy › Utility to measure sustained RAID throughput?
Posted by Taiji Miyagawa on May 22, 2006 at 8:54 pmDoes anyone here know of a OSX utility that can measure the sustained data rate/throughput for a RAID?
Taiji Miyagawa replied 20 years, 3 months ago 2 Members · 4 Replies -
Jeremy Garchow
May 22, 2006 at 9:19 pmTry AJA’s system speed test, it’s free. Will measure in MB/sec, streams, and frames per second.
If you need something that will measure across the entire distance of the raid, then yo will need something like iozone. Also, your raid manufacturer might have utilities built into their system to benchmark their Raids. You should ask them as well.
https://www.aja.com/ajashare/AJA_KONA_System_Test_v1.2.app.tar
Jeremy
Taiji Miyagawa
May 22, 2006 at 10:16 pmThanks Jeremy. We just bought into the AJA Kona and Xena line.
We’ll check this out.
Jeremy Garchow
May 23, 2006 at 1:57 amCongratulations! I’m sure you won’t be disappointed once you get up and running. AJA makes quality products.
Jeremy
Taiji Miyagawa
June 1, 2006 at 6:41 pmHmmm…tried the AJA utility, but I’m not sure what the “read” measurement is. Sure, I’d like to believe I’m getting 916 MEGABYTES/s sustained, but frankly, I find that hard to believe. Maybe I’ll have to contact AJA on this one.
I’m looking for something that can give me a sustained read measurement off of the RAID.
