Activity Forums DVD Authoring Utility to determine a PAL or NTSC DVD-5 Diskette
  • Utility to determine a PAL or NTSC DVD-5 Diskette
    Posted by William Mcqueen on July 23, 2005 at 11:38 pm
    Is there any utility out there that can determine if a recorded DVD is either PAL or NTSC; or other process? (There are no labels.) And if they’re set to zero region.
    Thanksfor your collective wisdom.
    Cheers,
    Bill in Toronto
    George Wing replied 21 years, 2 months ago 3 Members · 2 Replies
  • David Roth weiss
    July 24, 2005 at 10:04 am
    Bill,
    If they don’t play in an NTSC player, they’re PAL, and if they do their NTSC. Thats the utility…
    DRW
  • George Wing
    July 24, 2005 at 12:26 pm
    If you have a PC with a DVD drive that will let you explore the disc, you can use IFOedit to open up the VIDEO_TS.IFO (in the VIDEO_TS Folder). You should see some info that would point you in the right direction…
