Activity › Forums › Apple Motion › using your own image in a particle emitter
Posted by Terry Maloney on August 6, 2016 at 2:05 amHello
Is it possible to import your own image into Motion 5 to be used in a particle emitter?
Thank you.
TerryTerry Maloney replied 10 years, 1 month ago 2 Members · 4 Replies -
Mark Spencer
August 6, 2016 at 2:19 amYes – you can use your own image, or video, or text, or group of objects – just about anything.
Mark Spencer
Freelance Producer/Editor/Motion Graphics Artist
Apple-certified Master Trainer
Author, Motion 4 from Peachpit Press
https://www.applemotion.net -
Terry Maloney
August 6, 2016 at 3:02 amThanks, Mark, 😀
Could you please direct me to the place where you do that ?
Terry -
Mark Spencer
August 8, 2016 at 8:54 pmTerry, you just select the object you want and then make an emitter.
Mark Spencer
Terry Maloney
August 9, 2016 at 3:06 amHi Mark,
I thought you had to put the image in the contents folder/ particle images.
But if you don’t, this is much easier. Thanks a lot for your help. 😀Terry
