Activity Forums Maxon Cinema 4D using xpresso with time+trig first frame error
  • using xpresso with time+trig first frame error
    Posted by Lukasz Wieczorek on March 25, 2020 at 9:19 pm
    having this problem with xpresso using time with trig, I think. For some reason when it’s at frame 0, it doesn’t actually output “0” (I think) from what I can tell else it would pick the first index. But it also seems to set it when I leave it on the first frame(when its not playing), so if I drag and hover over it doesn’t work then I let go and it seems to set the index. guessing it’s outputting a null or something weird and its reading it as a 0 maybe? because right after the first frame it seems fine.
    here is the file (forum won’t let me upload)
    https://filebin.net/o0mwwvl7kf72cxpg
    here is the xpresso setup
    https://imgur.com/a/Avbme20
    View post on imgur.com
    Lukasz Wieczorek replied 6 years, 6 months ago 2 Members · 3 Replies
  • Brian Jones
    March 26, 2020 at 2:26 am
    Clones start numbering at 0 so the Range Mapper after the Trig should start at 0 (and run to 9 still since, I think, it gets Floored rather than Rounded)
  • Lukasz Wieczorek
    March 26, 2020 at 5:59 am
    so I set the output lower to 0 and output upper to 9, still seems to happen.
  • Lukasz Wieczorek
    March 28, 2020 at 9:15 pm
    uploaded a gif of whats happening in case that helps
    https://giphy.com/gifs/KHQ6oKURy7PHxmdBCd
