Activity Forums Canon Cameras using xha1 as external mic w/ FCP
  • using xha1 as external mic w/ FCP
    Posted by Chris Gallaway on July 29, 2009 at 1:51 pm
    Hey folks,
    I’ve used a professional mic connected through my camcorder as a pre-amp before in order to record narration with the voice over tool in Final Cut Pro. Was trying to set my XHA1 up for this purpose today, and whenever I try to select “DV Audio” in the Voice Over Tool pulldown, I get the following message:
    “The selected sound input device is unavailable. It may be in use by another application, disconnected, or improperly connected, or may be conflicting with a video output device.”
    I’ve been troubleshooting this for a while, and here’s what I’ve tried:
    1. The camcorder is in record mode, connected to a firewire port with no other firewire devices connected to my mac.
    2. No other programs are running when I attempt this.
    3. I’ve switched “External Video” to “Off” in the View menu as recommended in the FCP manual.
    I feel like the problem must be in settings somewhere, either on my camera or in FCP. Any suggestions out there. I’d much appreciate some help.
    Thanks, Chris
    Chris Gallaway replied 17 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
