Activity › Forums › Apple Final Cut Pro Legacy › Using white text in FCP
Posted by Paul Williams on February 22, 2006 at 1:17 pmHi everybody,
Just was wondering if somebody could tell me the best font to use when editing with FCP ie. If using a white text on a black background. whats the right opacity, drop shadow if using one and percentage of colour in order for it to look good and be broadcast safe?.
Thank guy
Paul
Kulcha ProductionsJohn Calhoun replied 20 years, 7 months ago 7 Members · 6 Replies -
Walter Biscardi
February 22, 2006 at 1:54 pmchoice of font and background are wholly up to you depending on what you’re doing. There is no “correct font / background” for broadcast, it’s whatever you and the producer determine are right for your project.
To keep it broadcast safe, keep your whites to 85 – 90% and use your scopes to determine whether or not your whites are too hot.
Walter Biscardi, Jr.
https://www.biscardicreative.comDirector, “The Rough Cut”
https://www.theroughcutmovie.comNow Posting “Good Eats” in HD for the Food Network
Bouncing Account needs new email address
February 22, 2006 at 2:02 pmGreat Titles with the DV Codec
By Philip Hodgettshttps://www.creativecow.net/articles/hodgetts_philip/titles/index.html
Simple but valuable info.
Jeff Carpenter
February 22, 2006 at 3:10 pmYou can certainly make any font work, but serif fonts can be more difficult to get perfect sometimes.
Serifs:
https://www.webopedia.com/TERM/s/serif.htmlBecause video is make up of horizontal lines, the tiny little bits on serif fonts can get lost or distorted between lines if your text is too small. It can certainly be done, it’s just something else to watch out for as you adjust your text.
Andrew Wise
February 22, 2006 at 3:35 pmI don’t think you will have a need for a drop shadow on a black background.
For other color backgrounds try:OFFSET: 3
ANGLE: 135
COLOR: BLACK
SOFTNESS: 10
OPACITY: 75There are no hard & fast rules (that I know of). Just play around with the settings and use what you think looks good.
Andrew -
Arnie Schlissel
February 22, 2006 at 5:58 pm[walter biscardi] “There is no “correct font / background” for broadcast”
True, but there are definitely wrong fonts! In general, you should stay away from any thin fonts. Script, serif & italic fonts should be used with caution.
Arnie
https://www.arniepix.com -
John Calhoun
February 23, 2006 at 1:41 amI generally don’t use the text tool or boris in FCP; I usually use Photoshop. I can be a lot more creative in PS and is a necessary tool when dealing with graphics from clients. If you don’t know PS, you need to add it to your list of applications.
(if you don’t know PS don’t sweat these steps. Just print them out for later) For broadcast safe in PS, add an adjustment layer to your graphic and clamp your “output levels” to 16 and 235 (not 0 and 255). This will look a little strange in PS, but will look ok on your NTSC monitor and be broadcast legal.
It’s also better to add drop shadows in PS to save on rendering time on slower machines.
To merge your graphic elements onto a single layer *including drop shadows and glows*, create a new layer and hit Command, Option, Shift “E”. This will merge all of your layers in a single pass. You can then save and import into FCP as a PSD or save the single layer as a targa (.tga) file, but you then need to make an alpha channel. To do this you Command click the layer to create a selection, then go to Channels and hit the ‘Save Selecetion as a channel’ button at the bottom. This creates your alpha channel. Then just ‘Save As’ a Targa file at 32 bits.
pxlmvr
