Activity › Forums › VEGAS Pro › using videoclips from an other vegas project
  • using videoclips from an other vegas project
    Posted by Robert Adama on August 6, 2014 at 2:14 pm
    Hello everybody
    How do I import Videoclips from an older Vegas Pro Project into a actual Project. I know how to use an previous project into an actual one, but not, how to use only a few clips. Since I still use HDV filmfootage (recorded on DV Tape), I cannot use the data showing up the explorer.
    Just for your info: I am a newcomer with Vegas Pro and used upto now AVID Liquid.
    Thanks a lot for your help!
    Just as an feedback for the COW Comunity: I use frequently the question/answer dialog and learned a lot!!
    Rob Adama Switserland
    Robert Adama, Switserland
    Windows7 64bit ASUS P7P55D Intel i7 2.8 GHz, 16BB DDR3-1333
    Graphic HD 5770 128 bit
    Vegas Pro9 and
    Win XP 32bit with AVID Liquid 7.2
    Andrew Lenczycki replied 12 years, 1 month ago 4 Members · 6 Replies
  • Bob Peterson
    August 6, 2014 at 4:03 pm
    I always use the File Import command. It has several options. I always the import Media option which imports files from wherever they are stored on my system, but I see there is also a Media from Project option. Perhaps that is what you are looking for.
  • Andrew Lenczycki
    August 6, 2014 at 4:08 pm
    I also use DV video. Not sure how you’ve done in the past, but I always acquire the video segments from the DV tape/recorder and save as files on my hard drive. You can then select these clips while in Vegas, using the Explorer tab to find the file(s) on your hard drive, then drag it onto your timeline.
    Secondly, you could open two instances of Vegas, in the first, load the project that contains the events (you call clips) you want to use. Then you can right click on the event, select Copy, then go to your second instance of Vegas running (where you want to put the copied event), and then right-click and select Paste on the track you want to put this event.
    Andrew Lenczycki
  • Robert Adama
    August 7, 2014 at 8:19 pm
    Thx a lot for replying so quickly! and I’ll try it out this weekend and let you know the outcome.
    [as I mentioned, I used to use AVID Liquid 7.2 (Little brother/sister of AVID Media Composer-) there the procedure is simillar but not the same]
    Windows7 64bit ASUS P7P55D Intel i7 2.8 GHz, 64BB DDR3-1333
    Graphic Sapphire HD 6870 128 bit
    Vegas Pro 12. Additionally
  • Theo Van laar
    August 8, 2014 at 11:18 am
    I always simply drag the files from windows explorer directly onto the timeline.
    Theo
  • Robert Adama
    August 16, 2014 at 7:48 pm
    Super, it worked and so I can use the events (clips), which I have already on my harddisk.Tnx again for your help!
    Unfortunately, I have now “imported” unconciously, an other problem.To explain is rather difficult, but I uploaded a detail-Picture. See my link:
    https://i1.creativecow.net/u/219976/sm/soundshift2.jpg
    If I move the videotrack, the sound track remains where it is, indicating how much timeshift between video and Sound exist. Apparently I introduced this my self. How can I move- in one go- Video and Sound, without causing a shift (asynchron sound/Video)
    I would be very obliged, if you could give me a advise!
    And, sorry disturbing you again!
    Robert
  • Andrew Lenczycki
    August 17, 2014 at 10:45 pm
    Easy! You need to put the video and sound events into a Group. Left-click on the video event, then shift-left-click on the sound event (which should select both of them), then press the G key (or alternatively, with the two events selected, right-click on them and select Group|Select New from the context sensitive menu that appears). Bam! Done!
    Andrew Lenczycki
