Activity › Forums › Apple Final Cut Pro Legacy › Using video of different formats
  • Using video of different formats
    Posted by David Buckner on April 19, 2013 at 12:11 am
    Hello everybody.
    I’m editing a film together from two different video sources. I’ll list their info at the bottom of this post. My question is: what’s the best way to combine these two formats? Ideally I’d like the film to be 24p and in 4:3. What’s the best way to confirm both of these video sources to a format similar to that?
    Source 1:
    This is a transfer of Super 8 footage. I shot the footage at 18fps but when I had it transferred to digital, the file I got back was in the following format with black bars on each side of the screen.
    Framerate: 29.97
    Framesize: 1920 x 1080
    Compressor: Apple OpenDML JPEG
    Pixel Aspect: Square
    Field Dominance: Upper (Odd)
    Datarate: 8.8 MB/sec
    Source 2:
    This I shot on mini-DV using a XH-A1 set to SD 4:3 mode 24p
    Framerate: 23.98
    Framesize: 720 x 480
    Compressor: DV/DVCPRO – NTSC
    Pixel Aspect: NTSC – CCIR 601
    Field Dominance: None
    Datarate: 2.9 MB/sec
    I can give the capture settings for Source 2 if needed but I don’t see why it would be. So yeah, what’s the best way to confirm these two clips? Thank you a bunch in advance this project is super important to me
    Chris Tompkins replied 13 years, 5 months ago 3 Members · 3 Replies
  • Steve Eisen
    April 19, 2013 at 3:59 am
    You will have a very hard time with FCP 7 with this project. There is no easy way. Avid Media Composer and Premiere Pro can handle this a lot better.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • David Buckner
    April 19, 2013 at 4:40 am
    Thank you for your reply. Unfortunately I only have access to FCP7. What’s the best way to go about it with that restriction?
  • Chris Tompkins
    April 19, 2013 at 5:29 pm
    Then, you should encode all media top the same specs using your favorite compression software or hardware card upon ingest.
    Chris
