Activity Forums Adobe Illustrator Using vector paths
  • Using vector paths
    Posted by David Gilhooly on May 23, 2006 at 8:03 am
    Hi people
    I am using Illustrator CS2 and want to use Vector paths to draw an image. Then i want to import that image in to Zaxwerks pro animator. How do i access Vector paths so that i don’t get any error messages when i attempt to import the file in to pro animator?
    thanks
    David
    Mike Gondek replied 20 years, 3 months ago 2 Members · 1 Reply
  • Mike Gondek
    June 1, 2006 at 8:24 pm
    Never got to use Zaxwerks, btu you can try to copy a ptath to the clipbaord and paste (works in After Effects if you have your illustrator preferences set to aicb)
    Otherwise you may want to reference what file format s zaxwerks accepts (pdf, eps or .ai) If you use .ai you may wnat to try turning off or on PDF comaptibel when saving.
    Sorry I don’t haev Zaxwerks expereince, but noone answered your post so hope this helps.
