Activity › Forums › Adobe Premiere Pro › Using transitions from PPro 2.0 in Prem 6.5
  • Using transitions from PPro 2.0 in Prem 6.5
    Posted by Michael Alexander on September 17, 2007 at 11:17 am
    Hi!
    I have both, PPro 2.0 and Prem 6.5.
    As I am more familiar with Prem 6.5. (as I am used to it), I would like to use transitions included in PPro 2.0 also in 6.5.
    (especially “Kugel”, which is the German name for this transition).
    It is possible to use transitions from PPro 2.0 also in 6.5?
    And if so, how can I identify the file I need and how is it to install it for 6.5.
    Thanks your help!
    Regards
    Michael
    Blast1 replied 19 years ago 3 Members · 2 Replies
  • Vince Becquiot
    September 17, 2007 at 1:18 pm
    Sometimes you just have to move on 🙂
    P 6.5 is much less reliable (and workable)than PP2, and that reliability may just get worse when using newer effects in the old interface.
    Vince
  • Blast1
    September 17, 2007 at 3:48 pm
    Most probably wouldn’t work anyway as its different editing engines, thats why projects aren’t backward compatible.
