Activity Forums Apple Final Cut Pro Legacy Using TIFF sequences in FCP?
  • Using TIFF sequences in FCP?
    Posted by Steve Price on May 15, 2008 at 1:25 am
    Good morning Cowers,
    Am I doing this right?
    I’ve shot some sequences with a Phantom HD camera at 2048 x 1080 @ 1000 frames-per-second. That bit went fine.
    I have the RAW picture cine files stored on hard drive. Using the Phantom software I’ve converted the RAW sequences into TIFF files, also at 2048 x 1080.
    I then put the entire folder of TIFFs into my FCP timeline, with the preferences set to 1 frame duration for each TIFF.
    Then I exported the sequence as an uncompressed QuickTime file to use in my edit.
    It seems to have worked fine, but it all seems a bit too simple really. Keep thinking I must be missing something.
    Does anyome have any tips for using TIFF sequences in FCP?
    Steve.
    Lee Devine replied 17 years, 8 months ago 3 Members · 3 Replies
  • Arnie Schlissel
    May 15, 2008 at 2:06 am
    You’re pretty close.
    Here’s what I’d do:
    1- Export the .tiff sequence from the Phantom software as you’ve been doing.
    2- Open the .tiff sequence in Quicktime Pro (shift-command-o to open an image sequence).
    3- Export from QT using settings that exactly match the timeline settings you want to use.
    4- Import into FCP & edit into your timeline.
    5- Have a nice coffee, espresso or cappuccino, you’ve earned it!
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Steve Price
    May 16, 2008 at 10:40 am
    Thank you Arnie,
    I’ve tried it and it’s working very well – playback seems to be a bit smoother this way too.
    Cheers,
    Steve.
  • Lee Devine
    December 15, 2008 at 3:36 pm
    Hi
    I did a shoot on friday with a Photron SA1 which shoots loads of TIFFs, When i try and open the TIFF sequence in Quicktime pro the fastest frame rate i can choose is only 60fps!
    I shot at 2000fps so does anyone know how i change the settings. I will be editing using FCP.
    Cheers
    Lee
