Using throw with another expression
Hi all – I want to use the throw expression to animate a null along the y axis, but have another expression moving the null on the x axis already – when I put in the throw expression it overides the movement that the other expression is giving the x axis – is there any way I can limit the throw to just changing the y value?
Here are the two expressions I want to use –
// Throw (move at a constant speed without keyframes)
veloc = 10; //horizontal velocity (pixels per second)
y = position[0] + (time – inPoint) *veloc;
x = position[1];
[x,y]and
transform.position + 45*(0,thisComp.layer(“midi”).effect(“ch_3_pitch”)(“Slider”)-60)
Any help would be amazing!
Cheers!
