Activity Forums Adobe After Effects Expressions Using the time stretch value from Premiere Pro within a Mogrt?
  • Using the time stretch value from Premiere Pro within a Mogrt?
    Posted by Alexander Baumeister on October 17, 2022 at 5:29 pm
    Is there a way to use the time stretch value from Premiere Pro within a Mogrt when this Mogrt gets stretched in the Premiere Pro Timeline?
    Is there a cheat for this or is this simply unpossible by system architechture.
    Clearly you can input a value manually in a text field in Premiere Pro Graphic Essentials panel and process this value in After Effects within your script.
    But can you get the exact time stretch value from a Mogrt in the Premiere Pro Timeline automatically somehow?
    In order to process the time stretch value from a Mogrt e.g. to maintain the animation speed of a animation done in After Effects no matter how it will be stretched in Premiere Pro.
    Filip Vandueren replied 3 years, 11 months ago 2 Members · 1 Reply
  • Filip Vandueren
    October 18, 2022 at 6:55 am
    Unfortunately no, the mogrt doesn’t know how much it gets stretched, or anything else of what’s happening in premiere.
    Having the user manually input the length of the resulting clip into a text field is also the only workaround I’ve been able to come up with.
