Activity Forums Adobe After Effects Expressions Using the sampleImage expression in a script – possible?
  • Using the sampleImage expression in a script – possible?
    Posted by Nils Schildhauer on November 13, 2012 at 2:18 pm
    Hi everyone,
    I’m relatively new to both After Effects and scripting After Effects. (I do have quite a bit of programming experience though, mostly in C#).
    I’m trying to use the sampleImage method from inside a script. This script is supposed to create a grid of evenly spaced objects based on the alpha channel of the selected layer in the composition (e.g. a logo).
    Here’s what I have so far:
    var myComp = app.project.activeItem;
    if(myComp instanceof CompItem) {
    // make sure one layer is selected
    var myLayers = myComp.selectedLayers;
    if(myLayers.length == 1){
    //get selected Layer
    var selectedLayer = myComp.selectedLayers[0];
    //define h
    var h_x = 30;
    var h_y = 30;
    //define sample radius;
    var sampleRadius = [2,2];
    var samplePoint;
    //iterate over comp size, sample image.
    for (j = 0; j <= selectedLayer.height; j += h_y)
    for (i = 0; i <= selectedLayer.width; i += h_x){
    samplePoint = [i, j];
    sampledColors = 255 * selectedLayer.sampleImage(samplePoint, sampleRadius, false, 0);
    if (Math.round(sampledColors[3]) > 128){
    //if the sample has at least 50% opacity, create a new Light at the sample point.
    myComp.layers.addLight("Light " + i + " " + j, samplePoint);
    }else{
    alert("Select exactly one layer to use as a mask!");
    }else{
    alert("Please select a composition.");
    Unfortunately, on execution I get an error telling me the function selectedLayer.sampleImage is not defined.
    What am I missing here? Slightly modified to directly select a layer by name inside an expression works like a charm.
    Is the sampleImage method simply not available in scripts? Is there any typecast I need to use before accessing the sampleImage function?
    Any help would be greatly appreciated! =)
    Nils
    Adobe Master Collection CS6 on Windows 7 at work and CS 5.5 on OS X at home.
    Working on a regular basis with Premiere Pro, After Effects, Audition and Photoshop.
    Ashraf Hamdi replied 6 years, 7 months ago 5 Members · 5 Replies
  • Dan Ebberts
    November 13, 2012 at 2:24 pm
    Unfortunately, sampleImage() is not available directly to scripting. However, your script can apply a sampleImage() expression to the layer, harvest the result, and then remove the expression. Kind of a pain, but it works. Come back if you have trouble working out the details.
    Dan
  • Ryan Detert
    December 20, 2012 at 6:47 am
    Did you figure this one out? I’m in the same boat.
  • Nils Schildhauer
    December 22, 2012 at 6:05 pm
    Hi, as Dan said you cannot use sampleImage directly in a script. I ended up using a construct like the one below…
    Note that I am only sampling one channel (the alpha channel in this case). There is a color effect control which can store all the channels at once…
    var mySlider = selectedLayer.Effects.addProperty("Slider Control");
    var h_x = 10;
    var h_y = 10;
    for (j = 0; j &lt; selectedLayer.height + h_y; j += h_y){
    for (i = 0; i &lt; selectedLayer.width + h_x; i += h_x){
    var expr = "Math.round(255 * sampleImage([" + i + "," + j + "], [" + sampleRadius + "," + sampleRadius + "])[3])";
    mySlider.property(1).expressionEnabled = true;
    mySlider.property(1).expression = expr;
    var res = mySlider(1).value;
    //do stuff
  • Phil Spitler
    January 8, 2013 at 1:19 am
    I just tried this in CS5.5 and get a “missing )” error at the following line.
    for (j = 0; j < selectedLayer.height + h_y; j += h_y){
    Any idea?
    Thanks .
    Phil
  • Ashraf Hamdi
    January 6, 2020 at 3:26 pm
    it works perfectly in CS6, but in CC2020 it takes a very long time and giving me a “Not responding” crash, can you please update the code to work in CC2020 ?
    for (L = 0; L &lt; Cd+(steps/FPS) ; L += (steps/FPS))
    for (m = 1; m&lt;256; m++)
    myRec = app.project.activeItem.layer("Histogram grid").content("Histogram").content(m)
    myRec.size.setValueAtTime(L,[1,0]);
    for (j = 0; j &lt; Ch + hY; j += hY)
    for (i = 0; i &lt; Cw + hX; i += hX)
    var expr = "var Tar = thisComp.layer('Histogram');\rMath.floor(255* rgbToHsl(Tar.sampleImage([" + i + "," + j + "], [" + sampleRadius + "," + sampleRadius + "],true,time))[2])";
    var res = mySlider(1).valueAtTime(L,false)+1;
    myRec = app.project.activeItem.layer("Histogram grid").content("Histogram").content(res)
    Ht = myRec.size.valueAtTime(L,true)[1]+(SampleValue/12)
    if (Ht > 118) Ht = 118
    myRec.size.setValueAtTime(L,[1,Ht]);
    //prog.value += (1/SSS)
    //problem is here
    Ht = 0
    res = 0;
    mySlider(1).setValueAtTime(L,0)
    myLayer.remove();
    shapeLayer.moveAfter(myComp.layer("Histogram frame"));
    Status.text = "Ready"
    mainWindow.update();
