Activity Forums Adobe Premiere Pro Using the pen tool to create opacity mask almost always actives rotate function!
  • Using the pen tool to create opacity mask almost always actives rotate function!
    Posted by John Smith on March 6, 2018 at 3:49 am
    I’m trying to use the pen tool and create a opacity mask. Yet, while attempting to draw the mask in the program monitor, almost every single time, as I click the pen tool to add the point, it turns into the rotate tool and shifts the mask to a new rotation orientation.
    I would do anything to permanently shut off the rotate function, or at least have it active only if I hit a key on the keyboard. I’m finding this to be extremely difficult to use as is.
    I have played around trying to figure out what triggers it the rotate function, but I cannot figure out any pattern. Nothing seems to override it, either. It seems like Premiere is extremely concerned that I might want to rotate my entire mask, rather than actually draw it in the first place.
    Using 2017 Premiere Pro
    Michiel Niesten replied 8 years, 6 months ago 3 Members · 2 Replies
  • Jerry Wise
    March 6, 2018 at 11:27 pm
    i have the same complaint. i usually magnify the image in the program monitor to avoid the problem. like go to +100 or +150 etc.
  • Michiel Niesten
    March 8, 2018 at 11:40 am
    Same problem here. I either zoom in on the program monitor or adjust the mask when it’s “finished” (dragging/adding points seems not to activate the rotation as easily.)
    Michiel
