Activity › Forums › Apple Final Cut Pro Legacy › Using The Levelator
  • Using The Levelator
    Posted by James Dow on March 2, 2010 at 2:54 pm
    Is anyone using “The Levelator” to help even out the audio levels on their FCP projects? I’m going to try it out but was hoping for a few tips. Should I export an AIFF of just the dialog tracks, without any music in the mix? Would it work if the music is in the mix?
    James
    JPD
    Steve Cohen replied 16 years, 7 months ago 5 Members · 4 Replies
  • Paul Figgiani
    March 2, 2010 at 4:08 pm
    The Levelator is designed to process spoken word. Export your dialog tracks, process, and reincorporate into your project.
    Scroll down and read What is the Levelator?
    https://www.conversationsnetwork.org/levelator
    -paul.
  • Mark Petereit
    March 2, 2010 at 4:11 pm
    I just started using it for sermon videos for my church, but just my pastor’s mic channel during the sermon. I simply export the audio to an AIF, run it through Levelator and paste it back in.
    But I’m pretty sure Levelator was designed for spoken words. I wouldn’t recommend it for music.
  • John Fishback
    March 2, 2010 at 4:35 pm
    I’m a bit anal about audio. I spend a lot of time “leveling” tracks. Since finding the Levelator, I’ve been letting it do the heavy lifting. It’s a terrific program. Donate if you can (I have no connection with Levelator).
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
  • Steve Cohen
    March 3, 2010 at 3:12 am
    I use Levelator all the time.
    It does a great job.
    The manual (or what every you want to call the page or two they include) says that is is for voice onlu, not music.
    Steve Cohen
    Senior Editor
    O2 Media Inc.
