Activity Forums Apple Final Cut Pro Using the Blade tool to cut the top connected clip
  • Using the Blade tool to cut the top connected clip
    Posted by Luke Hartley on August 23, 2011 at 12:41 am
    I have a timeline with 3 connected clips stacked on top of each other.
    I select the top connected clip, switch to my Blade tool and then start playback.
    When I hit my shortcut key B to slice the top clip in 2 during playback it works great, but if I hit B again, it splits my bottom timeline clip in 2 and not my top connected clip.
    Is there a way to keep blading the top connected clip with out stopping playback, selecting the top one again and starting all over?
    Neil Goodman replied 15 years ago 3 Members · 3 Replies
  • Neil Goodman
    August 23, 2011 at 4:49 am
    i think if you hit c while hovering a clip it might select letting you do a combination of c an b to slice but yea your correct this happens, but ithink fcp 7 did the same thing, if you had a clip selectend and contol v’d, nothing would be slected and it would slice whatever is v1 a1and2
    Neil Goodman: Editor of New Media Production – NBC/Universal
  • Oliver Peters
    August 23, 2011 at 12:39 pm
    Actually in FCP7 Cntrl-V follows the track selections based on the auto-selection/track-enable toggles. If only V2 is enabled, then only V2 is “razored” .
    Oliver
    Orlando, FL
    http://www.oliverpeters.com
  • Neil Goodman
    August 23, 2011 at 5:06 pm
    yup, thats what i meant, but haveing a clip selected overwrites which track its cuts on until a cut is made and that track is deselected again.
