Activity Forums Adobe Premiere Pro Using “-t” arguments in WebM Plugin, no multithread when rendering? Losing my mind figuring it out…
  • Using “-t” arguments in WebM Plugin, no multithread when rendering? Losing my mind figuring it out…
    Posted by Thomas Brigantino on March 5, 2016 at 4:47 am
    Just some background on footage:
    Two 10s clips 3840×2160 60fps exported from After Effects in uncompressed AVI format.
    One 10min clip 2560×1440 60fps H.264 screen capture using Open Broadcast Software.
    I have been having a heck of a time trying to figure out the best Codec for YouTube and I finally came across, what I think to be, the appropriate encoding format for upload. There are no errors of out of sync, nothing stating I should have processed for streaming and it processes all the way through without getting stuck on 95%. When I rendered out in WebM none of those issues surfaced and it took me an ungodly long time to figure it out as I am still learning proper workflow with multiple file formats.
    The most recent challenge is slow processing and I know the 3840×2160 60fps output is heavy and it seems Handbrake uses all of my CPU’s which are Two i7 3960X 3.3 but for some reason the arguments I put into the Text Area in WebM plugin just doesn’t seem to take and I can’t figure it out.
    I tried variations of -t, –cpu-used, –good and I am at a loss.
    I am not sure if it is the mixed formats or my command line syntax is off, I have no idea…
    If you can share any guidance on how to fix this or if you think I should fix my entire approach with a better workflow, I would follow that tune in a heartbeat…
    Thanks in advanced for any shared guidance…
    Thomas
    Brendan Bolles replied 10 years, 6 months ago 3 Members · 3 Replies
  • Tero Ahlfors
    March 5, 2016 at 6:36 am
    Have you tried using the H264 presets for youtube?
  • Thomas Brigantino
    March 5, 2016 at 12:44 pm
    I have an it just causes issues. WebM is the way to go.
  • Brendan Bolles
    March 21, 2016 at 8:27 pm
    The WebM plug-in defaults to the VP9 codec, which is pretty darn slow. It also defaults to 2 passes, which takes longer and the first pass is single-threaded.
    You can speed things up by turning off 2-pass and using the VP8 codec instead. The price will be some loss of image quality, but you could try increasing the data rate to compensate.
