Activity › Forums › Adobe After Effects › Using system clock time in expressions?
Posted by Tim Kurkoski on January 10, 2006 at 5:47 pmIs it possible to use the system time and date (ie., the current time stored in my computer’s clock) in an expression? I’ve been looking for a way but haven’t successfully found one yet.
Tim Kurkoski replied 20 years, 8 months ago 4 Members · 7 Replies -
Filip Vandueren
January 10, 2006 at 6:07 pmEventhough you can easliy do it in Javascript,
not all javascript methods are mirrored in the aftereffects expression language.Why do you need this ?
Tim Kurkoski
January 10, 2006 at 8:33 pmA friend asked if it can be done, actually, and I’m not sure of his ultimate motives. I suspect he simply wants a “true random”, if you will. One that shows different results each time you launch the application and isn’t simply the result of a pre-determined equation that’s the same each time in a given situation.
It was an interesting question, so I decided to see if it could be done. I did find references to other types of JavaScript libraries that can do clock functions, but obviously AE can’t access those. A pity.
Dan Ebberts
January 10, 2006 at 9:24 pmI think the nature of AE and expressions makes system time unusable if you think about it. If you were using it as random seed, that number would be changing even while you’re just sitting on the same frame. With the way expressions work, there’s no way to just seed the random number generator once and have that affect the entire comp. And there’s no way to pass the seed from one frame to the next. I’m guessing it wasn’t an oversight to leave it out, because it just wouldn’t work the way you would want it to.
Dan
Tim Kurkoski
January 10, 2006 at 11:01 pmGood point, Dan. In a perfect world, I’d still like to see something like it, even if it would only be a static value. (What would be the point of having a text layer running the current time, anyway? It would change each time you rendered.) Maybe something that would grab the last modified date or last accesssed date of the AE project file, like GetLastDate. If somebody truly wanted a clock, it could be incremented. Ah, well. Maybe if I cook up some clam chowder or pork chops for the engineers they’ll do it for me.
Filip Vandueren
January 11, 2006 at 1:18 amYou can always write a script that puts the current date in the text-content of a hidden text-layer, or the name of a null, then build your scripts from that….
but it’s a bit useless…
Tim Kurkoski
January 11, 2006 at 5:35 pmThat actually occurred to me last night, too. But you’re right, it’s too much work.
