Activity Forums VEGAS Pro Using SV Pro 8 – AVCHD to PAL DVD
  • Using SV Pro 8 – AVCHD to PAL DVD
    Posted by Craig Cooper on May 27, 2008 at 8:42 am
    Hi All,
    What is the best procedure in Sony Vegas Pro 8 to convert HD AVCHD footage to DVD PAL?
    I have tried rendering to AVI YUV which looks great but then looks blocky when cut to DVD.
    Do I start a project with PAL(720×576) and import AVCHD or start project in HD then import AVCHD then render to HD, then render to PAL DVD?
    Please suggest which template I should use as I have tried many and am not happy with the rendered output.
    Cheers Craig
    Peace Talks Hamper War in Middle East
    John Rofrano replied 18 years, 3 months ago 2 Members · 1 Reply
  • John Rofrano
    May 27, 2008 at 1:25 pm
    I find it best to keep your project in the same format that you will deliver in. This ensures that there are no surprises especially when matching aspect ratios. So I would start with a PAL DV Widescreen project and then add your AVCHD files to that and render using the DVD Architect PAL Widescreen video stream template and a corresponding AC3 template (Stereo or 5.1) for audio.
    ~jr
    https://www.johnrofrano.com/
