Activity Forums Adobe After Effects Using Stroke
  • Using Stroke
    Posted by Chuck Obernesser on March 20, 2008 at 8:08 pm
    Hi to all,
    What I am doing is I have a very simple logo. I want to use the stroke effect to make it appear. I haven’t used the stroke effect a great deal and what I am using four different masks to make the logo appear. The thing is I tried to time it where the logo branches off then the next mask starts the reveal. When I rendered it out the timing was all off. I turned the sequential option on and off and off made it worse. Any idea’s?
    Chuck
    Obernesser Productions
    http://www.obernesserproductions.com
    Jan Sherlink replied 18 years, 6 months ago 3 Members · 2 Replies
  • Randy Mcwilson
    March 21, 2008 at 6:52 am
    You could try by doing the animation on 4 separate layers. That way you can control the timing more accurately.
    Hope this helps…
    Eternity…don’t miss it for the world.
  • Jan Sherlink
    March 21, 2008 at 1:42 pm
    It would be better to assign a stroke separately to each mask with “Path” so each stroke instance addresses only one mask. Set the Paint-Style to transparent to see all stroke-effects.
    And just keyframe each Stroke effect separately
    cya,
    Jan
