Activity Forums Adobe After Effects Using stills from AE to create an image
  • Using stills from AE to create an image
    Posted by Jerry Smith on July 25, 2016 at 2:35 pm
    I’m not sure what the best way to go about this is.
    The content is ultimately all typography, simple shapes, and a few solid colors.
    The content lives across many AE projects. I want to create stills from those projects.
    Then stack and display them like playing cards, say ace through king of spades. I was originally inspired by the carousel in Finder on a Mac. But I think it will look more like a beauty pageant where all the contestants are coming down a long straight staircase. The stack will be used as an image on a web page.
    Question 1: What format should I use when I export the stills from AE?
    Question 2: What program should I use? AE is easiest because I can just think of all the spacing in 3d terms, since that is what I originally had in mind. It doesn’t really matter however because I don’t think anything is going to be at an angle and so I can accomplish what I want with just positioning and scaling? So would Photoshop be better?
    The MAIN CONCERN is to keep the typography super sharp.
    Eric Santiago replied 10 years, 1 month ago 2 Members · 4 Replies
  • Jerry Smith
    July 25, 2016 at 3:13 pm
    Actually, after playing with it some more, I guess I do want some rotation/3D. So, then I guess I should keep it in AE. What’s the easiest way to get all the still in one place in AE? I don’t think I want to import 20 AE projects into 1 just to get a still from each.
  • Eric Santiago
    July 25, 2016 at 3:41 pm
    Are all the projects setup the same e.g. HD, 4K, etc…
    Whats wrong with importing 20 AEP in one project.
    I do it all the time and avoids screwing up the original.
    Much faster than opening one project at a time.
    Then if your setting up in 3D you might have to make changes to the static frame so no need to open up the original project again.
    I export all kinds of frames from PSD, JPEG, PNG, etc…
    They all work to up to 30k pixels.
  • Jerry Smith
    July 25, 2016 at 4:00 pm
    There was lots and lots of incest in the creation of the projects. I would bet even money that the whole thing will crash the first time I try and do it. Too many pre-comps of pre-comps all with the same names. But yeah, that’s probably the best way to do it. There won’t be any need to modify things however.
  • Eric Santiago
    July 25, 2016 at 6:55 pm
    Unless you have the final output on QuickTime files.
    Then just import those.
    Is the final output for high res print?
