Activity Forums DaVinci Resolve Using Split and Add Function With A Flattened QT
  • Using Split and Add Function With A Flattened QT
    Posted by Chris Martin on May 30, 2012 at 5:11 pm
    So I have an edl and a preconformed QT. I want to use the “Split and Add” feature in Browse menu (so I can attach mattes to necessary shots). When I go to use Split and Add with said QT I navigate to edl as prompted but Resolve splits the QT up into clips that do not match the edit.
    Both edl and QT are at 23.98 and when I use the same edl in Conform menu as a PreConform Resolve reads it spot on.
    I’ve wound up just dinking on the “split souce clips for preconform” under settings to split out clips which worked fine but the clips had to remain in Root folder.
    Anyone run into this? Am I trying to use this feature incorrectly?
    Cheers, Chris
    Diego Delanoe replied 13 years, 9 months ago 3 Members · 2 Replies
  • Sascha Haber
    May 31, 2012 at 7:04 am
    No really, you either need to use the preconform function or even better, load you clip NOT into the media pool, but instead right click on it, say Load into scene detection, load your EDL here, split and check your edits.
    Then load that into your media pool and voila…should be fine
    A slice of color…
    DaVinci 8.2.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / Quadro 4000
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
  • Diego Delanoe
    November 13, 2012 at 4:42 pm
    Hey Sascha, so how do you load an EDL into the scene cut detection, i cant find it out…
    THE PANIC PROPAGANDA
