Activity Forums Adobe After Effects Expressions Using sourceRectAtTime and if/else
  • Using sourceRectAtTime and if/else
    Posted by Chris Stetson on November 16, 2018 at 5:00 pm
    Hello,
    I’m new here and trying to figure out how to combine the use of sourceRectAtTime with if/else.
    I have two text layers on top of a shape layer. I’d like the shape layer width to adjust based on whichever text layer has the greatest width. Below is the expression I’ve written and I am not getting any errors, but the if/else statement doesn’t seem to be working. The shape layer adjusts based on the first text layer, but if the second text layer is greater than the first, it does not adjust accordingly. Any help would be greatly appreciated. Thank you.
    Chris Stetson
    var A = thisComp.layer("NAME");
    var W1 = A.sourceRectAtTime().width;
    var B = thisComp.layer("Title");
    var W2 = B.sourceRectAtTime().width;
    var Y = content("Rectangle 1").content("Rectangle Path 1").size[1]
    var P = thisComp.layer("Control").effect("Text Padding")("Slider");
    if(W1>W2){
    W1
    }else{
    W2
    [W1||W2,Y]+[P+P];
    Geoffrey Amend replied 7 years, 8 months ago 3 Members · 3 Replies
  • Dan Ebberts
    November 16, 2018 at 5:24 pm
    I’d do something like this:
    var A = thisComp.layer(“NAME”);
    var B = thisComp.layer(“Title”);
    var Y = content(“Rectangle 1”).content(“Rectangle Path 1”).size[1]
    var P = thisComp.layer(“Control”).effect(“Text Padding”)(“Slider”);
    W = Math.max(W1,W2);
    [W,Y]+[P,P];
    Dan
  • Chris Stetson
    November 16, 2018 at 6:58 pm
    Dan! Thanks so much for your help. That did it. I had to modify slightly since this caused the height to change, which I wanted it to stay constant, but I was able to fix that. Thanks again for your help.
    var Y = 380
    [W,Y]+[P,0];
  • Geoffrey Amend
    January 2, 2019 at 12:15 am
    Hi. I’m tryin to apply this to a template that will include either 2 or 3 lines of text. But my question I think is regarding an expression I can add to the slider as I need the padding to be as follows:
    Z= the height of the font
    top edge and bottom edge of shape = 2/3 of Z
    left padding = Z
    distance between text layers = 1/2 Z
    And finally, the right edge of shape won’t be a vertical line as in a rectangle but a 60 degree angle from lower right to upper right and the padding on the lower right will need to also be determined relative to Z….
    Any help is greatly appreciated. Thanks very much.
    Thank you!
