Activity Forums Adobe Premiere Pro Using sound-compressors?!
  • Using sound-compressors?!
    Posted by Stefan Johansson on December 14, 2005 at 10:57 pm
    When editing material that has pretty much ok sound, I normally just use
    the ‘clean comp’ to the master track, and set the ceiling to about -1db to get the
    peaks out.
    But what is the correct procedure when editing material where the sound
    levels vary a lot?
    Is there anything one definately should NOT do, using compressors, that
    may ruin the sound.
    //Stefan
    Marc Bauwens replied 20 years, 9 months ago 2 Members · 3 Replies
  • Marc Bauwens
    December 15, 2005 at 10:25 pm
    You could use a direct x plugin called Ultramaximizer by a company called Waves. Great for levelling sources with varying audio levels. Their Rennaissance compressors are also great, even with heavy compression.
    The thing to avoid above all is brick wall limiting because this really squashes the sound.
  • Stefan Johansson
    December 16, 2005 at 12:10 am
    What exactly does ‘brick wall limiting’ mean;-)
  • Marc Bauwens
    December 17, 2005 at 9:18 am
    Brick wall limiting is a technique where you use a device or plugin called a limiter and in turn this device allow you to preset an output level above which the signal isn’t allowed to go. When the exceeding levels are mild, it’s fairly ok, but with material containing a lot of level changes or dynamics the sound appears to be squashed and can sound very nasty. To use with absolute care if you really have no other option.
