Activity › Forums › Apple Final Cut Pro Legacy › Using SonyHDV camera as converter from FCP to NTSC (or HDTV)??
Posted by Ben Ged low on August 21, 2006 at 5:12 pmI’ve heard conflicting rumours. Can I use my SonyHDV camera to act as a throughput (as I once did with the PD150) to output my clip or sequence to an NTSC (or HD?) monitor?
Ben
Ben Ged low replied 20 years, 1 month ago 4 Members · 5 Replies -
Matthew Brunn
August 21, 2006 at 6:15 pmI haven’t found a way yet.
Hope this helps-
Matthew
Quad 2.5 G5
OSX 10.4.X
Ram 4GB
FCP 5.1/AE 6.5/DVDSP4 -
Richard Martz
August 21, 2006 at 6:52 pmYou might be able to do that but why would you put that many hours on your camera?
Richard Martz
MagicMartz MediaFinal Cut Pro HD
Kona LH
After Effects
PhotoShop
Illustrator
Lots of other Fun Stuff! -
Steve Connor
August 21, 2006 at 9:06 pmThe answer is a definite NO.
This question comes up weekly at the moment!
Ben Ged low
August 21, 2006 at 11:31 pmThank you Steve,
I suspected as much. I’m off to check out the Decklink and AJA Kona cards.
Much appreciated.
Ben
Ben Ged low
August 22, 2006 at 7:50 pmHi Steve,
I got a $45 DVI adaptor … DVI out to consumer HD. Plugged it into a Toshiba consumer HD. Works just fine. I have to sacrifice an LCD screen, but I can at least be sure what the final output is going to look like on a consumer HD TV.
B.
